Lug nut size? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 12-01-2009, 07:35 AM   #1
Rodeo
Grand Am Series
Default Lug nut size?
What size lug nuts are on the 2010 Ford Fusion? (say the 18" SAP wheels for example).
I bought a new air compressor that came with an impact wrench so I might as well get the thin walled lug nut sockets too.
2010 Milan Premier V6 FWD,Moon & Tune, Remote Start, RSS., Tuxedo Black w/ Medium Light Stone Leather interior
Rodeo is offline   Reply With Quote
Old 12-01-2009, 09:47 AM   #2
Khanaar
Go-Kart Driver
Send a message via AIM to Khanaar Send a message via MSN to Khanaar Send a message via Yahoo to Khanaar
Default Re: Lug nut size?
same as most ford cars, 3/4, or 19mm. both will work
2010 Sangria Red Fusion S.
2.5l 150hp Duratec 4
6 speed manual trans
18 inch steel wheels with 225/45ZR18 Goodyear Eagle GT
otherwise... Stock, for now.
Khanaar is offline   Reply With Quote
Old 12-01-2009, 11:50 AM   #3
Rodeo
Grand Am Series
[quote author=Khanaar link=topic=161954.msg3437846#msg3437846 date=1259678870]
Thanks..
Think I'll get one of those multi sets (7 sockets) with the plastic sleeves so I can be prepared for any wheel. At least I'll be able to put my own snow wheels on too finishing with a manual torque beam type torque wrench. That should work, right?
Old 12-01-2009, 12:09 PM   #4
2010SEL
Grand Am Series
2010SEL's Avatar
I had to use a 13/16" on mine. You need to check and see what you have on your car.
2010SEL is offline   Reply With Quote
Old 12-01-2009, 12:12 PM   #5
Fuze-ion
Go-Kart Driver
I have one of the various lug nut sockets with the plastic liner to protect your chrome lug nuts. This set is great, but expensive, I'm sure you can find cheaper sets.
http://www.griotsgarage.com/product/...+socket+set.do
Fuze-ion is offline   Reply With Quote
Old 12-01-2009, 04:17 PM   #6
Rodeo
Grand Am Series
[quote author=Fuze-ion link=topic=161954.msg3438018#msg3438018 date=1259687572]
This is the set I was going to get:
http://www.harborfreight.com/cpi/cta...emnumber=94421
Old 12-01-2009, 06:14 PM   #7
jasonl
Go-Kart Driver
$70 for sockets seems silly. How many times do you change your wheels that you think you're going to marr the lugnuts?
jasonl is offline   Reply With Quote
Old 12-01-2009, 06:35 PM   #8
Rodeo
Grand Am Series
[quote author=JasonL link=topic=161954.msg3438613#msg3438613 date=1259709278]
The set pictured above is $49.95 and besides I will need to change four wheels twice a year at bare minimum (mount and demount snow wheels), and have 4 cars in our household that may require their use on occasion. On top of that it'll be 9 deep sockets that I can use for other reasons (having a brand new air impact gun and no sockets to go with it.)
Old 12-01-2009, 08:32 PM   #9
Khanaar
Go-Kart Driver
the OEM nuts are a crapy cheap stainless steel tin covered nut, they dont rust, so as long as you dont beat them up and rattle them off tight, you should be fine. I suggest any old 19mm thinwall socket will work since you arent going to use it often. I used an impact and a standard little thinwall socket on my wheels the other day when I put my winters on without so much as a scratch on my stock nuts. it all depends how careful you are rather than the tool itself
Old 12-01-2009, 09:33 PM   #10
ravenzfusion
Go-Kart Driver
i bought a set of campbell hausfield impact sockets at walmart for 20 bucks. look near the automotive section, its by the air compressors. they have a 3/8 in drive set and a 1/2 inch drive set. i bought the 1/2inch drive. the set came in a case, they were black impact sockets and had 7 sae and 8 metrics i think. i just took the 18 inch sport rims off my car and this set came in handy. works great for 20 bucks.
2010 fusion sport FWD
2000 zx2 s/r 5 speed
ravenzfusion is offline   Reply With Quote
