Is the Info Cluster "miles to E" accurate? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 10-01-2009, 02:50 PM   #1
cobra jet
Grand Am Series
Default Is the Info Cluster "miles to E" accurate?
I was just wondering how accurate the info meter is when it comes up w/ the "low fuel" message and it shows the "miles remaining to E" - how accurate is that, and how low can one really go w/o actually running out of fuel?
Meaning, if the meter shows 38 miles left (after low warning light messages), will the car be totaly out of gas as it hits 38 miles, or is there a reserve?
- Phil
1994 Cobra coupe #0013, 2011 Genesis Coupe, 2011 Tucson GLS
Drive like water flows, follow the path of least resistance.
cobra jet is offline   Reply With Quote
Old 10-01-2009, 03:49 PM   #2
bbf2530
Default Re: Is the Info Cluster "miles to E" accurate?
[quote author=Cobra Jet link=topic=157439.msg3349830#msg3349830 date=1254423048]
Hi Cobra Jet. There is no exact answer to your question. First of all, there is a reserve when it hits zero. However, that reserve should not be explored, as running the tank down that low should be avoided (it can be harmful to the engine, as clearly explained in the Owners Manual). If you do a "Search" you will see that against better advice others have tried it in the past, and everyone has come up with different numbers to empty.
Second, the "Distance to Empty" is only a rough average. It takes into account the mileage you were getting for a predetermined amount of prior driving. So the short story is that when it says "38 miles to empty", it will hit zero before or after you have driven 38 miles, according to whether those last 38 miles are highway, city or some other sort of driven miles.
It will likely almost never be the actual number of miles that the readout says.
The best way to look at the readout/warning is like this: It is not our car giving us an exact mileage countdown. It is our car telling us, "Hey stupid, find a gas station quick! Can't you see we are almost out of gas?" :lmao:
Hope my answer was not too confusing.
Old 10-02-2009, 12:37 AM   #3
blazerdude20
Grand Am Series
[quote author=bbf2530 link=topic=157439.msg3349930#msg3349930 date=1254426580]
i've never personally driven it to 0, but my gf drove it for 20 miles after it hit "0" this past week because she couldnt get to a gas station. so there is a reserve but there can be a lot of sediments built up in the bottom of a gas tank that you dont want in your fuel pump or engine.
blazerdude20 is offline   Reply With Quote
Old 10-02-2009, 12:51 AM   #4
shawngreen
Senior Member
Just last week on my way back from Colorado, I got to "0 miles to E" and then went another 30 miles. I bet I could have gone another 30 miles too, but I wasn't sure where the next gas station was. The actual gas gauge still showed about 1/8th of a tank which is why I did it. I think it's like a gas light and is meant as more of a warning than anything else.
shawngreen is offline   Reply With Quote
Old 10-02-2009, 10:44 AM   #5
roaf85
Short Track Racer
[quote author=shawngreen link=topic=157439.msg3350701#msg3350701 date=1254459085]
Probably, but I would not risk it.
What is the fuel tank size? Like 17.5 gallons? Usually when I hit the 30-50 miles mark it is around 14.2-15.1 gallons if I remember from my fill ups. So if I drove it to 0 I could probably go about 20-30 more miles.
roaf85 is offline   Reply With Quote
Old 10-08-2009, 07:20 AM   #6
2010SEL
Grand Am Series
2010SEL's Avatar
Not accurate at all. The MPGs calculated are always off 1.5-2.5 mpg on my car. So how could this be accurate, since all it is doing is calculating based on the same data?
2010SEL is offline   Reply With Quote
Old 10-08-2009, 12:27 PM   #7
bartman1
Grand Am Series
bartman1's Avatar
In my experience with both an '06 SEL and the '10 SEL there is about 2 gallons (good for another 50 miles) when the counter says "0 to empty". I have frequently let it hit 0 and when I fill up I can only get about 2 gals short of capacity.
I've read that that old wive's tale about sediment in the tank is wrong. The fuel pump pulls gas from the bottom of the tank all the time; that's the only way to run the tank dry. Therefore any sediment is constantly being removed and sent to the fuel filter.
bartman1 is offline   Reply With Quote
Old 10-08-2009, 12:43 PM   #8
bbf2530
Hi guys. This reply deals solely with running the tank to empty.
However anyone may feel to the contrary, Ford specifically warns against running the tank to empty, or running out of fuel. Directly from the Owners Manual:
Running out of fuel
Avoid running out of fuel because this situation may have an adverse
effect on powertrain components.
Actually it is not an old wives tail, since running the tank down to the bottom concentrates the contaminants in the tank. That means that at any one moment, the fuel pump is lines are pulling in more contaminants than if the tank had more fuel in it.
In addition, many modern fuel pumps 9I am not 100% sure about our fuel pump) have two pickups, so running the tank low forces the fuel pump to use the lower of the two pickups. That equals more contaminants.
Also, many modern vehicles use the fuel to cool the submerged fuel pump. So you run the tank low, you can overheat the fuel pump.
Just a few reasons to avoid running the tank low, if possible.
Hope this information helps.
Old 10-08-2009, 02:08 PM   #9
roaf85
Short Track Racer
[quote author=bbf2530 link=topic=157439.msg3360476#msg3360476 date=1255020217]
Running out of fuel
Question about contaminants. I am not a scientist, but I was wondering take this for example:
Turn some dirt in a glass and then pour some water into the same glass. Notice how the dirt mixes and then settles to the bottom.
Does this same thing happen lets say on the road if you are hitting bumps and turning etc. Doesn't the contaminants swirl around in the tank and intermix with the fuel? I am just wondering.
Old 10-08-2009, 02:17 PM   #10
bbf2530
[quote author=roaf85 link=topic=157439.msg3360640#msg3360640 date=1255025302]
Running out of fuel
Hi roaf. Less so when the tank is full, or fuller. There is less turbulence in a full tank, since there is more liquid and less air space. So any mixing contamination is more dispersed/less concentrated, if picked up.
In addition, a full (or fuller) tank also promotes less condensation in the tank, meaning less water in your fuel tank, which means less water in your fuel.
Just more (of many) reasons why it is always better to keep the tank on the full side.
This is common automotive information, although some may not know it.
