Special tool needed to compress rear caliper pistons? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 08-05-2009, 10:06 PM   #1
cos
Le Mans: GT Class
Default Special tool needed to compress rear caliper pistons?
I'm getting ready to intall a set rear brake pads. Do the rear caliper's pistons just get pushed in with a C-clamp (like the fronts) or is there a special brake tool needed to turn them in?
'06 Fusion - Black, 2.3/5 speed manual
SCT X3 (Steeda 93 tune)
cos is offline   Reply With Quote
Old 08-05-2009, 10:20 PM   #2
fatabbot
fatabbot's Avatar
Default Re: Special tool needed to compress rear caliper pistons?
Yes, you need the "special" tool to compress (really twist) the pistons in on the rear. My local NAPA carries it or you can get it from your local Ford parts dept.
fatabbot is offline   Reply With Quote
Old 08-05-2009, 10:30 PM   #3
TheUkrainian
F1 Driver
Send a message via AIM to TheUkrainian Send a message via MSN to TheUkrainian
Damn, at least I know what I gotta get before I change by pads.
Cleverly disguised as a responsible college student...
TheUkrainian is offline   Reply With Quote
Old 08-06-2009, 05:50 AM   #4
SGs Fuzion
Grand Am Series
Hi Cos....I've done this twice in the past 3 years (http://www.fordfusionclub.com/index....797#msg1412797)...I simply used a pair of needle nose pliers to rotate it clockwise back into the caliper (the puck has a indented '+'...12&6 0r 3&9 & twist)...squirt alittle WD40 around were the rubber seal contacts the puck so the puck rotates freely & won't damage the seal...also....make sure that the '+' is in the 12-6 position so that the 'stubs' on the inboard pad will align in the slot when you install the new pads...hope this helps...& saves sum $ ;-)
Razzi*Eagle Alloy 192*NS-1 255/45-17*Raybestos/C D Rotors *Magnaflow DE*SCT XCAL 2*Jusnes CAI/91T*Steeda TBS/STSB/Rear Mtr Mnt*SG SSI/ICADS*Vogtland 50MM*KYB GR2*Energy Suspension*Ichiba 15MM Spacers
->1ST STEEDA FUSION OF THE MONTH - JUNE 2007- http://www.steedafusion.com/fusion_of_the_month/
->JAN 2008 FFC COTM - http://www.fordfusionclub.com/index.php?topic=99295.0/
SGs Fuzion is offline   Reply With Quote
Old 08-06-2009, 08:54 AM   #5
fatabbot
fatabbot's Avatar
We did that when we changed out Spoon's pads and rotors. Having the actual tool (which cost $5 at my local store) was more than worth it when I replaced mine.
Old 08-07-2009, 11:34 PM   #6
cos
Le Mans: GT Class
Thanks!
Old 08-08-2009, 12:49 AM   #7
Cwick21
Short Track Racer
I just did this last week. I just used a large pair of pliers and took my time so I didn't damage the seal.
Vapor silver SE
SAP Moon & Toon
Sync
Flashing clear Sidemarkers
20% Tint Rear 35% Front
Cwick21 is offline   Reply With Quote
Old 08-08-2009, 08:52 AM   #8
ff09rt
Short Track Racer
I did a 4 wheel brake job yesterday and i used a universal caliper depressor kit. and make sure the the holes in the piston match up with the pad or it wont sit right.
ff09rt is offline   Reply With Quote
