What size allen wrench? - Oil Drain Plug - FordFusionClub.com : The #1 Ford Fusion Forum
Old 04-14-2009, 02:47 PM   #1
SMOWKIN
Bicycle Rider
Default What size allen wrench? - Oil Drain Plug
I have a 2008 Ford Fusion SE with a 2.3L I4.
Can anyone tell me what size allen wrench I need to use for the oil filter drain plug? For the life of me I can not figure it out.
SMOWKIN is offline   Reply With Quote
Old 04-14-2009, 05:24 PM   #2
koreySE
Le Mans: GT Class
Default Re: What size allen wrench? - Oil Drain Plug
None -- just remove the complete cap -- with Autozone cap wrench. I never removed mine. It's 1 less thing to worry about -- and 1 less o-ring to replace.
'10 MKZ AWD: White Platinum, Ultimate/Technology/Sport Packages. 20% tint, Steeda intake w/Airaid SynthaMax filter
koreySE is offline   Reply With Quote
Old 04-14-2009, 10:48 PM   #3
SMOWKIN
Bicycle Rider
That is what I am currently doing and it is a pain in the ass. Not to mention messy as hell.
[quote author=koreySE link=topic=141957.msg3059211#msg3059211 date=1239744242]
It's 1 less thing to worry about -- and 1 less o-ring to replace.[/quote]
Yeah, it is not that hard to replace the o-ring.. I'm really not too worried about that.
Does anyone know the wrench size?
Old 04-15-2009, 03:23 PM   #4
koreySE
Le Mans: GT Class
A Google search states 6mm for Mazda. Just buy a cheap set.
No matter what you do, oil changes will always be a pain in the Fusion
Old 04-15-2009, 03:33 PM   #5
SMOWKIN
Bicycle Rider
Thanks, I will have to give that a try.
Do you really think the oil change on the Fusion is that hard. Everything is right there. If you want to see a difficult oil change try a 2004 Honda Civic EX.. You have the take off the front drivers side tire, and have hands like a 5 year old.
The Fusion is a walk in the park compared to this beast.
Old 05-29-2009, 08:59 PM   #6
empire
Go-Kart Driver
I believe its 6 mm....http://robert.aitchison.org/tiki-pag...DIY+Oil+Change I never remove the allen screw just the whole cap. There is a coversion kit if you don't like the cartridge when you are out of warranty of course....http://www.mazda3forums.com/index.php?topic=146390.0
empire is offline   Reply With Quote
Old 06-08-2009, 11:20 AM   #7
ff09rt
Short Track Racer
Ya its a 6mm. i replace it every other oil change when i rotate my tires
ff09rt is offline   Reply With Quote
Old 07-01-2009, 12:38 AM   #8
piffusion
Short Track Racer
I am about to change the oil on my V6 this weekend for the first time, should i expect any surprises? Am I correct by assuming the tedious oil change process is only for the I-4 engines and not the V6? I do not have to swap out any o-rings do I?
Sorry I have not had a chance to get under the car yet.
Oxford White, Smoked sidemarkers, SAP Grille, Black Headlights
If you want black headlights for your Fusion like in my pic, PM me.
piffusion is offline   Reply With Quote
Old 07-07-2009, 09:48 PM   #9
empire
Go-Kart Driver
I have both engines and the six is easier . They make a special cap type wrench which has 36 flutes and fits the FL820S Motorcraft filter. I find it works the best and is available from Autozone.
Old 07-09-2009, 01:43 PM   #10
ff09rt
Short Track Racer
ya the v6 is so much easier. no gaskets to change just an fl-820 filter (motorcraft) and a 13 mm wrench.
