Oil capacity - FordFusionClub.com : The #1 Ford Fusion Forum
Old 03-16-2009, 10:11 AM   #1
biggee72
Default Oil capacity
I'm going to do my own oil this weekend..does anyone have the oil capacity for the 2.3? I can't find it in the search. Also IF you have it the mobil 1 oil filter #. Thanks!
Old 03-16-2009, 10:29 AM   #2
bbf2530
Default Re: Oil capacity
[quote author=biggee72 link=topic=139067.msg2996996#msg2996996 date=1237212669]
Hi biggee. From the Owners Manual:
2.3L Engine Oil Capacity - 4.5 quarts/4.25 liters.
Oil Filter Part # (Ford) - FL-2017-B I do not know the part # for the Mobil 1 equivalent oil filter. However, just ask the store staff for the Mobil 1 equivalent of the Ford part #.
Also, as an FYI, the following information is also mentioned in the Owners Manual, concerning oil changes:
When changing oil filter you must also replace the filter cap O-ring. The
oil filter drain plug O-ring must also be replaced whenever the oil filter
drain plug is removed. Reuse of the O-rings may cause engine oil leakage
and may result in severe engine damage. The customer warranty may be
void for any damage to the engine if the O-rings are not replaced.
Hope this information helps.
Old 03-16-2009, 11:06 AM   #3
biggee72
Thanks BBF, I don't have my owners manual w/ me since I drive the explorer to work and I wanted to go out during lunch to get the oil. As for the O ring..is that the o ring on the oil filter theyre speaking of? If so..I've never seen an oil filter that didn't include the o ring.
Old 03-16-2009, 11:15 AM   #4
06Ffusion
Le Mans: GT Class
The "O-Rings" comes with the filter, one for the cartridge housing and one for the cartridge housing drain plug. The fusion doesn't have a "Spin-on" oil filter, it is the cartridge type. If you choose to loosen the filter housing plug you'll need to replace that o-ring as well.
F2 Full Cold Air Intake, Steeda 93 Performance Tune, H&R Coilovers, F2 SS Brake Lines, Tinted Sidemarker Lights, 3rd Chrome Fascia Bar, Custom Emblems, Street Unit Motor Mount
06Ffusion is offline   Reply With Quote
Old 03-18-2009, 04:11 PM   #5
biggee72
FYI The Mobil 1 oil filter number is M1C153
