Engine removal Q&A - FordFusionClub.com : The #1 Ford Fusion Forum
Old 02-09-2009, 03:13 AM   #1
onehighfocus
Moped Rider
Default Engine removal Q&A
Well... I'll provides the Q's hopefully I can Get some A's
I need to replace my dead engine... see http://www.fordfusionclub.com/index.php?topic=130032.0
I have the full, two part, Ford shop manuals, but the described method for removal is to drop the cradle. Im sure this is by far the simplest method when you have a lift and the proper cradle support tools, but I dont.
So, on to the questions (and yes I have searched  )
1. Has anyone every pulled the 2.3 from the fusion/milan on here?
if so continue...
2. Is it possible to pull from the top of the engine bay? (standard old school methood)
if so continue...
3. Can the engine be pulled alone, or does the tranny have to go with it?
4. Is there any difference in the harness or required connections between the motor from a manual equiped car and that from an automatic equiped car.. i.e. My car is manual, if I get a motor from an automatic, will I need to swap the harness or anything else from my motor to the new one?
I think thats about the most of my concerns at the moment, but feel free to chime in with any advice for my upcoming project
Thanks for stoppin by
Silver - 2006 - MILAN - 2.3 - 5 Spizzle
onehighfocus is offline   Reply With Quote
Old 02-09-2009, 03:27 AM   #2
FusionLife
Le Mans: Prototype Class
Default Re: Engine removal Q&A
In regards to number two on your list, there are steel loops bolted to the engine that I can fathom of no use other than lifting the engine up and out. I marked them with red arrows. Can't help you with the other questions though.
Check out my Ride
FusionLife is offline   Reply With Quote
Old 02-09-2009, 11:41 AM   #3
crystallas
Le Mans: GT Class
Send a message via AIM to crystallas
Don't make a mountain out of a mole hill.
Going underneath is the way to go, and tool wise, it is not all that different.
I haven't done it on a Fusion yet, but I have done my fair share of swaps. When possible, going underneath is much quicker and safer.
Supporter of Freedom, Choice, and Consequence.
crystallas is offline   Reply With Quote
Old 02-26-2009, 10:45 AM   #4
Egz
Grand Am Series
When I did it on my Focus, it came out from the top. I envision it could be easier on the Fusion since there is more room to play with.
2003 Ford Focus ZX3 2.3l N/A = 206HP, 150ft-lbs; 13.96@100.88
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
Egz is offline   Reply With Quote
Old 03-01-2009, 06:17 PM   #5
black_magic
Go-Kart Driver
Send a message via MSN to black_magic
go from underneath. it will be alot easier. it will give you alot more room aswell as everything will be out in the open. this is how we do it at work and trust me its alot easier to do itthis way.
for the harness it should work as long as the harness doesnt connect to the transmission on your car. if it does then you will need to swap harnesses.
3. the tranny should probably come out at the same time as its a b!tch to undo while in the car if you dont drop the sub frame.
08 se I4, magnaflow exhaust, 18x8 american racing rims ( black with polished lip), 20% tint all around....... more to come
black_magic is offline   Reply With Quote
