For those with clunks/noises/knocks. 3 easy fixes. - FordFusionClub.com : The #1 Ford Fusion Forum
Old 02-01-2009, 01:31 PM   #1
Steve27
Go-Kart Driver
Default For those with clunks/noises/knocks. 3 easy fixes.
I've been frustrated for a while with three different clunks, knocks, and noises. I finally got them figured out and hope that this post will help a few people.
Clunk 1: This one was fixed the first time I went in. Dealer found it quickly. Going over speed bumps, noticeable clunk in front suspension: Dealer re-tightened loose strut mounts, clunk went away.
These 2 took a few trips to the dealer to figure out and will be explained together in detail from a post I made in another thread:
Clunk 2: Steering colum looseness/vibration/feedback/clunk
Clunk 3: Going from R to D, loud metallic clunk
YESSSS!!! Finally got it figured out! Had NOTHING to do with the trans like I dreaded! I talked with a Ford Tech and he rode in the car with me. We went from D-R-D-R over and over and found out it wasn't the trans making the knocking noise, it was the brake pad shims. Sounds crazy that they could make that loud of a noise, but that's what it was. Every time he hit the brakes, it would knock, and I was thinking it was the trans shifting. Turns out that the shims weren't designed to clamp on tightly and so they move a little when the piston presses on them and there's 2 or 3 so when they slap together they make a loud noise. The grease had worn off of them (Ford puts a few drops on them instead of coating them) and so there was no buffer between them. All we had to do was put some caliper grease on them and the sound completely went away.
The knocking and feedback in the steering wheel was due to a Mazda 6 TSB for lack of lube on the telescoping steering colum splines and coupler. He sprayed some white lithium grease on them and the problem completely went away. Two friggin' easy fixes and I LOVE my car again and don't feel like setting it on fire and rolling it down a hill, lol. Man, I got all worked up over almost nothing...it's always something small like that that's easily fixed but seems like the end of the world, haha. Now my car is perfect again!
The cool thing is that the Tech let me stay in the shop with him while he worked on my car and showed me everything he was doing. Props to him for fixing something easy that the other two trips to the shop couldn't.
Steve27 is offline   Reply With Quote
Old 02-02-2009, 10:42 PM   #2
albeys06
Le Mans: GT Class
Default Re: For those with clunks/noises/knocks. 3 easy fixes.
I know i felt the same way you did, but i know with such a sweet car it couldnt be to as bad as it seems. I wish there was more machanics like the one you had working on yours it seems like the service writer has something to hide when my car was in the shop.
albeys06 is offline   Reply With Quote
Old 02-03-2009, 06:43 PM   #3
confusioned
Go-Kart Driver
It's nice to hear some positive news about a mechanic......
2006 Fusion SEL V6
2008 Roush 427R Mustang
1986 Thunderbird Turbo Coupe
1995 Escort LX, Trusty, rusty,crusty and dusty daily driver
2000 Harley Davidson...stress relief without a prescription.
confusioned is offline   Reply With Quote
Old 10-15-2009, 07:23 PM   #4
jaero
Go-Kart Driver
[quote author=Steve27 link=topic=134999.msg2904577#msg2904577 date=1233513098]
Sorry to resurrect this old topic, but I think I have the same steering column problem. I FEEL a clunk in the steering wheel; I don't hear anything. I happens mostly at slow speeds when coming on and off the clutch - say in slow traffic - and more when turning left. Does this sound like what you had fixed?
Has the fix lasted since February, or has the problem returned? Do you know where the mechanic accessed the steering column splines? Do you happen to know the number on the Mazda TSB?
Thanks,
Jim
06 Mercury Milan - I4, Manual
jaero is offline   Reply With Quote
Old 10-15-2009, 07:30 PM   #5
biggee72
[quote author=jaero link=topic=134999.msg3371566#msg3371566 date=1255649039]
Thanks,
Jim
I have the same issue.
Old 10-15-2009, 07:45 PM   #6
jaero
Go-Kart Driver
I did some searching on Mazda sites a found the TSB #06-001-07-1738. Here's the link...
http://www.finishlineperformance.com...01-07-1738.pdf
The TSB identifies "Super Grease" to be used - Mazda part number 0000-77-230E-01. I can't imagine a spline joint should require a "Super" grease formula. I'll give wheel and drum bearing grease a try and see what happens.
Old 10-16-2009, 08:30 AM   #7
jaero
Go-Kart Driver
Well this fix worked for my car. I did it myself last night in about 25 minutes. It only requires one tool - a 12mm wrench - a bit of grease, and some time spent squeezed into the driver's side floor area. I used wheel bearing and brake drum grease which, being more viscous than the white lube that was in there, makes the telescopic steering column stiffer to operate, but I'd rather have that then a clunking feeling in the steering wheel. The difference was immediately apparent; the clunk is gone!!
If you're feeling a clunk or knock in the steering wheel, check out the TSB link in the post above. You may want to give this a try.
Old 10-16-2009, 01:06 PM   #8
UnderEstimated
Senior Member
Send a message via ICQ to UnderEstimated Send a message via AIM to UnderEstimated Send a message via MSN to UnderEstimated
So today my passenger side clunk is now accompanied by the driver side. The more you mention it, it may be the brakes. It always happens from R-D-R-D and I always come to a full stop before shifting. Also, the more I think about it, the clunk happens whenever I lift off the brake.
So where was the grease actually applied? The backside (metal plate) of the brake pad or the pistons themselves?
UnderEstimated is offline   Reply With Quote
Old 10-16-2009, 04:37 PM   #9
jaero
Go-Kart Driver
UnderEstimated, It sounds like your car is suffering from a different problem than mine. My clunk wasn't audible; I could just feel it in the steering wheel. The TSB addresses lack of lubrication in the steering column splines; that is where the grease is applied.
However, I do hear a small metallic click or clunk when switching from reverse to first gear after using the brakes. Several of my cars have made a similar noise that was due to the brake pads shifting back and forth slightly in the calipers. If the noise is especially bothersome and you want to try lubrication as a fix, you can apply some caliper pin lube (wheel bearing grease may be a good choice here too) to the edges of the metal brake pad backing plates, where they contact the calipers. It should at least quiet things down for a while.
Old 10-26-2009, 10:41 AM   #10
Steve27
Go-Kart Driver
[quote author=UnderEstimated link=topic=134999.msg3372598#msg3372598 date=1255712794]
It's applied to the brake pad shim. It's been probably 8-10k miles since then and I've had no problems . Quick, easy fix.
BTW, when the mech took off the shims to lube them, they looked like they didn't have but a drop or two of lube on them from the factory and all that had worn off. That's where the noise was coming from.
