How to locate your processor code (PCM) - FordFusionClub.com : The #1 Ford Fusion Forum
Old 11-01-2007, 04:26 PM   #1
larryinfl
Le Mans: Prototype Class
larryinfl's Avatar
Default How to locate your processor code (PCM)
Your Fusions PCM code is located behind your battery on the outside of your PCM. The PCM is attached to the firewall.
You may be able to see your PCM code without removing your cars battery. If you can see it please refer to Figure 3. If you have a hard time seeing the PCM code you can remove your battery to more easily see it. See Figure 2 to remove your battery.
Figure 1
If you need to remove your battery to view your PCM code; remove the two screws with the red squares around them pictured in Figure 2. You can try to view the PCM code without removing the battery by looking behind and below the battery. See the Orange box below.
Figure 2
Below you can see the Fusion's PCM code located on the PCM of your Fusion. It will be three letters followed by a number.
Figure 3
Steeda Autosports - THE Leader in Fusion Performance Products
Ford Fusion Performance Parts | Fusion Cold Air Intakes | Fusion Lowering Springs | Fusion Swaybars | Fusion Exhaust, and SO Much More!
Follow us on Facebook: Click Here
larryinfl is offline   Reply With Quote
Old 11-01-2007, 05:10 PM   #2
Jaysen
Default Re: How to locate your processor code (PCM)
Valuable Info.
Sticky!
Jaysen is offline   Reply With Quote
Old 11-01-2007, 11:14 PM   #3
08-con-fusion
Moped Rider
Just for clarification this is the code you need when ordering a tune ????
I am new sorry
08-con-fusion is offline   Reply With Quote
Old 11-02-2007, 08:28 AM   #4
larryinfl
larryinfl's Avatar
[quote author=08-con-fusion link=topic=93417.msg1826433#msg1826433 date=1193973251]
I am new sorry
That is correct.
Old 11-02-2007, 07:33 PM   #5
08-con-fusion
Moped Rider
[quote author=larryinfl link=topic=93417.msg1826952#msg1826952 date=1194006498]
I am new sorry
That is correct.
Thanks I am going to be getting a tune but I honestly am not sure now if I will be ordering it. Apparently there is a well know shop near me in the detroit area that will make a custom tune for your car using the dyno and I am bringing it there to get dyno's in a week or 2 but I may still go with ordering one depending on the price and after service details thanks for the quick response.
I have a stock auto 2.3l and will be dyno'd after every performance mod until it is complete I am going to take it as far as manufacturers and my job and wife will allow including a super charger. I am pretty sure I will be going with alot of steeda parts both performance and cosmetic as it is a project car for me and my son and he loves your cosmetic upgrades.
Old 07-06-2008, 10:22 PM   #6
shawngreen
Senior Member
Ok so I took out the battery, but am still unable to locate the PCM. Can someone help me please? Did they move the location of it in the 08's? Thanks.
shawngreen is offline   Reply With Quote
Old 07-07-2008, 08:48 AM   #7
Chris06Fusion
F1 Driver
Send a message via AIM to Chris06Fusion Send a message via MSN to Chris06Fusion
[quote author=shawngreen link=topic=93417.msg2443263#msg2443263 date=1215397355]
You're almost there. Its right under my arrow, against the firewall.
Former 2006 Fusion SEL owner. Now own a 2008 Audi A4 S-Line Quattro.
Chris06Fusion is offline   Reply With Quote
Old 07-07-2008, 08:55 AM   #8
shawngreen
Senior Member
Thanks for the help. I found it.
Old 08-12-2008, 10:54 PM   #9
NefCanuck
Okay does anyone have any tips to actually seeing what the heck is on that sticker in the V6 engine bay? :shock:
I had some friends remove the battery & pulled the battery tray away from area where we could see the sticker on the firewall, but between five of us and three different cameras we couldn't see the sticker clear enough to read it (It's almost like the sticker was placed too low)
I was thinking maybe try one of those flexible mirrors and then take a photo of the results? Or can a blank Xcal 2 read the PCM code? I have a blank one awaiting tuneage as I have a Steeda SRI on order through my local Ford dealer, along with some other bits, I'd really like a tune to compliment it but getting the code is proving to be impossible
NefCanuck
NefCanuck is offline   Reply With Quote
Old 08-13-2008, 08:03 PM   #10
kevjur
F1 Driver
Send a message via AIM to kevjur Send a message via Yahoo to kevjur
[quote author=NefCanuck link=topic=93417.msg2536855#msg2536855 date=1218596045]
NefCanuck
[/quote]I used a mirror to get mine, didn't take out the battery or anything.
kevjur is offline   Reply With Quote
  FordFusionClub.com : The #1 Ford Fusion Forum > Sponsors > Steeda Autosports
