Engine Knocking noise? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 02-20-2007, 02:27 PM   #1
douglas307
Short Track Racer
Default Engine Knocking noise?
Do any of you guy's have a engine knocking noise at idle? I went to my dealer and they told me that it's normal. I've read about ticking noise and I am not sure if is the same thing.
20' inch rims, eibach springs 1.6, flashing side markers, switched to leather seats and K&N air filter.
douglas307 is offline   Reply With Quote
Old 02-20-2007, 03:57 PM   #2
bassnutz
Grand Am Series
Send a message via Yahoo to bassnutz
Default Re: Engine Knocking noise?
If you get some bad gas, it might make it knock a bit. How long has it been doing this?
Black 2007 Fusion SEL V6
Blacked out front Grille
Tinted Windows
SCT 91 Torque Tune- Jusnes Modified (Amazing difference)
Steeda Throttle Spacer & CAI
2 Infinity Kappa Perfect 10's Audiobahn A2200HCT 2-Channel Amp Audionbahn A2002T 2- Channel Amp Boss Audio CAP25BK 3 Farad Second Skin Damplifier Pro. MB QUART RCE-268 REFERENCE 6x8/5x7 Infinity Reference 9613i 6"x9" 3-way 300w
bassnutz is offline   Reply With Quote
Old 02-20-2007, 04:25 PM   #3
slaterracing
F1 Driver
Send a message via AIM to slaterracing Send a message via MSN to slaterracing
[quote author=douglas307 link=topic=70012.msg1218932#msg1218932 date=1171999673]
what motor do you have?
slaterracing is offline   Reply With Quote
Old 02-20-2007, 04:53 PM   #4
captainhook
Grand Am Series
My I4, like every other 4 cylinder that I has made a ticking noise from the valves at idle.
Sounds normal if you have an I4, I can't speak for the v6 though.
2006 Milan
2004 Focus
Have you supported your local volunteer fire department lately?
captainhook is offline   Reply With Quote
Old 02-25-2007, 12:45 PM   #5
drjkel
Moped Rider
Yes. I have a definite knocking noise at idle on my I4. It is faint, but audible, only at idle with radio off and it is not valve noise or injector clack. It is NOT correlated with engine speed, that is, if I slightly rev the engine in neutral the knock does NOT increase in frequency. It does not always occur at every idle. I suspect an emissions-related solenoid, somewhere. If winter ever goes away here in WNY I will find it.
drjkel is offline   Reply With Quote
Old 02-25-2007, 02:13 PM   #6
bbf2530
Hi douglas307. It's always hard to diagnose over the Internet, because one persons definition of a "knocking" or "ticking" sound is different than another. However, while some faint "ticking" can be considered "normal" in some engines, what I would define as a "knocking noise" is not.
I would think about stopping at another Dealer and asking their opinion. Or, do you have a mechanic that you trust, who could listen and give their opinion?
I hope it's nothing, and good luck!
Old 03-01-2007, 06:00 PM   #7
mtl1977
Go-Kart Driver
What trans? (or did I miss that info?)
My smoked manual had a dowel pin on the flywheel come loose and knock about 10,000 pits inside the bell housing before going through the case.
no longer posting on here...
mtl1977 is offline   Reply With Quote
Old 03-11-2007, 05:16 PM   #8
kaboom
Grand Am Series
On the v6's the most common "ticking" noise comes from the exhaust camshaft driven water pump. It's not necessary to have it fixed it's not harming anything, but there is a service procedure for it.
'07 Sel 3.0
ASA 20's on BFG KDW 2's, Steeda Cai, Sct laptop tuned, Magnaflow CB, 15%tint, Eibachs, Billet Grille, Pioneer avic-d3, Phoenix gold comps,coax's,500.4,1200.1,Spl 2 farad cap, Alpine Type-X 12, 0 gauge 3 wire setup. SoundDestroyer deadening.LOTS OF LOUDNESS.
kaboom is offline   Reply With Quote
Old 03-11-2007, 08:55 PM   #9
whatup
Grand Am Series
Send a message via AIM to whatup Send a message via Yahoo to whatup
I have the I-4 and I have alittle tcking at idle. I think it is normal for the 4 bangers.
Pioneer AVIC-D3
K&N Typhoon Intake-TWM Short Shifter
Whiteline Strut Tower Brace
6000k HID's-Jusnes 89 Performance Tune
Magnaflow Catback Exhaust
whatup is offline   Reply With Quote
