car pulling to the right - FordFusionClub.com : The #1 Ford Fusion Forum
Old 08-03-2006, 07:59 AM   #1
07BlackFusion
Moped Rider
Send a message via AIM to 07BlackFusion
Default car pulling to the right
since i bought my fusion, it pulled badly to the right like it needed an alignment... took it back to the dealer, they tried to align it, but couldn't. they said the upper control arms on both sides were bad. So they ordered them in, replaced them and aligned it and told me everything was good. I took the car for a test drive... still pulls slightly to the right but i wasnt going to worry about it.
I go to the beach with my dad the next day to mustang week in myrtle beach, sc and the day after i come back i go to work in my car, as i'm coming back from work into my apartment, there is a slight right turn with a dip in it. I always go really slow through the dip to avoid hitting it hard, and as soon as my left front tire drops in the dip i hear a popping noise in the front end of the car and now my car pulls even harder to the right.
Took the car in yesterday and they are keeping it overnight to work on it and they tell me it will be fixed today. Anybody else had this much trouble with their suspension?
07BlackFusion is offline   Reply With Quote
Old 08-03-2006, 10:06 AM   #2
waldo
Le Mans: GT Class
Default Re: car pulling to the right
The Fusion is very sensitive to alignment due to the suspension design. If the camber and caster is not well matched left and right, it can induce pull. Unfortunatly Mazda didn't design in any provision for adjustment, so Ford created a "service" upper control arm that can shift the caster slightly to try and fix cars that are bad. This sounds like what your dealer did.
The popping though sounds like something else. Likely during the installation the dealer didn't torque something properly. My guess is that they torqued the lower front shock bolts while the car was in the air, thus preloading the bushings.
Try to get them to give you a copy of the final alignment printout.
waldo is offline   Reply With Quote
Old 01-05-2007, 07:39 PM   #3
urnews
Le Mans: GT Class
I am rapidly becoming very disillusioned after reading all of these types of horror stories about the Fusion.
Boz
2007 V6 SEL AWD Fusion
Horrific mileage: 14.8 mpg city
Oxford white/Dark charcoal
Heated leather, Moon roof, ABS
urnews is offline   Reply With Quote
Old 01-07-2007, 07:14 AM   #4
otaku
Le Mans: GT Class
Well all new cars have at least a few issues, ford is usually at the industry average with companies like lexus being among the best but even they have a few issues per new car. I thought mine was out of alignment but after having it checked and driving some more I think I'm just paranoid about stuff being wrong
best of luck
2007 Ford Fusion V6 SEL AWD
k&n drop in filter ( not anymore)
Steeda CAI Steeda tuned Silencer delete mod (using steeda bling)
Ford Fusion winter mats Ford Fusion Premium carpet mats
Tinted windows steeda strut tower brace
otaku is offline   Reply With Quote
Old 01-07-2007, 04:41 PM   #5
urnews
Le Mans: GT Class
[quote author=otaku link=topic=53199.msg1137056#msg1137056 date=1168168461]
best of luck
Otaku,
I think it's typical to give a vehicle closer scrutiny when it's new. As it gets older the idiosyncrasies don't seem to matter as much, are accepted as what they are. But little things can count a lot toward overall satisfaction, like the convenience of having a light in the glove box or having a lighted ignition switch.
Cars that won't track in a straight line on a smooth highway at 60 mph, ones that drift to the left or right, obviously have an alignment problem that should be corrected and should be correctable, too.
Old 01-08-2007, 06:51 PM   #6
waldo
Le Mans: GT Class
[quote author=urnews link=topic=53199.msg1135284#msg1135284 date=1168040355]
Boz
You're complaining about one guy who had a problem 5 months ago? Ford's built about 60,000 Fusions since then, so that means 59,999 are fine!
Old 01-08-2007, 06:59 PM   #7
urnews
Le Mans: GT Class
Quote from: urnews on January 05, 2007, 06:39:15 PM
I am rapidly becoming very disillusioned after reading all of these types of horror stories about the Fusion. Sad
Boz
Waldo,
I suppose that does put things in their proper perspective. I just don't like reading about problems with a model that I own, out of fear that mine will go haywire, too. Boz
Old 01-13-2007, 08:18 PM   #8
thereisnospoon
Le Mans: Prototype Class
OK, if you dogstomp the accelerator and you notice that the car pulls to the RIGHT, then you're paranoid. The thing is DESIGNED to do this as a precautionary measure. If you dogstomp it and it pulls to the LEFT, then you need to have that checked out because LEFTWARD is TOWARDS oncoming traffic.
[img width=361 height=100]http://www.fmvperformance.com/forum_items/gallery/17017_31_08_08_1_44_28.jpg[/img]
Past Real/Ford cars: 86 Mustang 5.0 Convertible (in garage on blocks), 94 Ford Mustang, 2002 F150 4.2V6, 2006 Ford Fusion
Current cars: 2008 Lincoln MKX (for wifey), 2010 SHO
thereisnospoon is offline   Reply With Quote
Old 01-15-2007, 03:43 PM   #9
douglas307
Short Track Racer
Yeah mines does that when I'm in a complete stop and I accelerate it goes just a bit to the right. So i guess is design to do that, I suppose?
20' inch rims, eibach springs 1.6, flashing side markers, switched to leather seats and K&N air filter.
douglas307 is offline   Reply With Quote
Old 02-19-2007, 01:40 AM   #10
thereisnospoon
Well, when you're flogging it from a stop, the right wheel receives much of the power which is also why it goes to the right. The AWD versions don't do it at all.
