Author Topic: TSB 07-05-10 (Wind Noise)  (Read 2462 times)
ciscoford23
  • Grand Am Series
  • Site Posts: 324
  • Transaction Count: (0)
  • Date Registered: December 03, 2005, 03:20:35 PM
  • Forum Member
« on: March 01, 2007, 06:40:36 PM »
FORD: 2006-2007 Fusion
LINCOLN: 2006 Zephyr
2007 MKZ
MERCURY: 2006-2007 Milan
ISSUE:
Some 2006-2007 Fusion and Milan, 2006 Zephyr and 2007 MKZ vehicles built before 12/1/2006 may exhibit a customer concern which may be described as a wind noise around the B-pillar or the upper rear area of the glass on the front doors.
ACTION:
Replace the window run seal on the front door exhibiting the issue.
« Last Edit: March 09, 2008, 08:45:41 PM by ciscoford23 »
Carlson
  • Moped Rider
  • Site Posts: 24
  • Date Registered: December 20, 2006, 10:20:58 PM
  • Car Model: Fusion 3.0 SEL
  • Car Year: 2007
Re: TSB 07-05-10 (Wind Noise)
« Reply #1 on: April 22, 2007, 09:22:50 PM »
My car was at the dealership for this TSB work. Dealer ordered new window seals, but Ford shipped the same ones that were installed on the car. Ford also said that new details will not be available until August! :huh:
Chris06Fusion
  • FMVsuperMod
  • F1 Driver
  • Site Posts: 4721
  • Transaction Count: (5)
  • Date Registered: May 17, 2006, 12:28:48 PM
  • Think with your dipstick!
    • Webshots Pictures of Car/Car Shows
  • Car Make: Ford
  • Car Model: Fusion SEL V6
  • Car Year: 2006
« Reply #2 on: April 22, 2007, 10:02:40 PM »
Sorry, but I have to raise the flag  :bs:.  I think they just don't want to reorder the correct part.  Many others have had this addressed and it was fixed.
3D Carbon spoiler, Steeda Dress-up, Redline hood struts, Steeda Tunes running 93 octane, Flashing side marker, Steeda tower brace. Steeda intake, Steeda TB spacer, Clear side markers, Steeda rear sway bar
douglas307
  • Short Track Racer
  • Site Posts: 173
  • Date Registered: June 23, 2006, 11:34:32 AM
  • Forum Member
  • Car Model: Ford Fusion SE I-4 2006 Dark Blue
  • Car Year: 2006
« Reply #3 on: April 24, 2007, 02:24:31 PM »
I was told the parts where on backorder.
20' inch rims, eibach springs 1.6, flashing side markers, switched to leather seats and K&N air filter.
BCKA8
  • Go-Kart Driver
  • Site Posts: 71
  • Date Registered: June 21, 2007, 02:04:23 PM
  • Car Model: V6 SEL
  • Car Year: 2006
« Reply #4 on: January 23, 2008, 03:43:39 PM »
I was told by the service advisor that there is a freeze on ordering the parts for the pass side. They went ahead and replaced the driverside and now its worse than before. WInd noise like crazy here and no fix in sight. Weak game FORD, weak game!!!!
Carlson
  • Moped Rider
  • Site Posts: 24
  • Car Year: 2007
« Reply #5 on: January 28, 2008, 09:37:45 PM »
Same here! They replaced the seals, but the noise is still there.  :thumbdown:
Nuowner
  • Grand Am Series
  • Site Posts: 267
  • Date Registered: January 18, 2008, 11:47:30 AM
« Reply #6 on: January 31, 2008, 12:22:27 PM »
Don't wait until they notify you aboout the parts being in... keep on them about it.  I had a Dodge dealer refuse to take care of a problem because I was out of warranty, even tho they supposedly had ordered the parts long before and well within warranty... they just never bothered to let me know they were in, despite them wanting three different ways to contact you when they place the order.  Too bad for me.  :x
BCKA8
  • Go-Kart Driver
  • Site Posts: 71
  • Car Model: V6 SEL
  • Car Year: 2006
« Reply #7 on: July 18, 2008, 02:09:18 PM »
NEW INFO AVAILABLE. Check with dealer.
The freeze on parts is over and I will be getting the TSB done next week on the passenger side, I'll post the outcome once its done.
BCKA8
  • Go-Kart Driver
  • Site Posts: 71
  • Car Model: V6 SEL
  • Car Year: 2006
« Reply #8 on: August 08, 2008, 07:25:44 PM »
UPDATE:
Wind noise has been fixed. A much tighter seal on the passenger side window. The TSB worked
Cobra Jet
  • Mustang Enthusiast, Automotive Hobbyist
  • Short Track Racer
  • Site Posts: 249
  • Date Registered: September 28, 2009, 05:56:06 PM
  • FMVenthusiast
  • Car Make: Mercury
  • Car Model: Milan I4
  • Car Year: 2007
« Reply #9 on: March 09, 2010, 01:50:28 PM »
For those that have had thier seals replaced under this TSB - is there any noticable difference in that actual physical appearance of the new seal when compared w/ the original?
Also, is this the seal that is found at the top of the door (when opened) and the same seal that can be seen against the top of the pillar when the door is shut?
- Phil
1994 Cobra coupe #0013, 2004 Ford Explorer, 2007 Mercury Milan
Drive like water flows, follow the path of least resistance.
torquelover
  • Go-Kart Driver
  • Site Posts: 69
  • Date Registered: September 09, 2009, 12:47:11 AM
  • FMVenthusiast
  • Car Make: Ford
  • Car Model: Fusion
  • Car Year: 2006
« Reply #10 on: March 31, 2010, 08:24:38 PM »
Yes, there is a difference. However, if they do both sides, you'll not notice it as much. Since only my driver's side was done, it is very noticeable to me. Much thicker, and a shinier material as well.
On my car, it was the rubber seal between the window and the door frame, not from the door frame to the body as I thought it might be.
