Author Topic: HOW TO: Check for wheel clearence for the Brembo brake kit  (Read 969 times)
larryinfl
  • Gold Sponsor
  • Le Mans: Prototype Class
  • Site Posts: 1217
  • Transaction Count: (13)
  • Date Registered: October 27, 2006, 02:58:05 PM
  • Steeda Performance
« on: January 06, 2009, 05:41:50 PM »
I've had a few questions about how to properly check if the Brembo brake kit will work with certain wheels as far as clearance. The template provided by Brembo to check clearance is not very clear, so I figured I'd take a few photos to show you all how to check.
The template you will need can be found here:
http://www.steedafusion.com/installs/files/brembo_fusion-mazda_brake_template.pdf
First you will need to cut out the outlined template like this:
Next you will need to line the thinner part of the template up with the dead center of the wheel. Also, make sure the template is laying flat against the inside of the wheel.
Next move the the template over the back of the spoke like shown. If the template hits any part of the back of your spoke or the inside of the wheel the brake kit will not fit.
This photo is an example of a wheel that would support the Brembo kit
This is a photo of a wheel that WILL NOT support the Brembo kit. Notice how the template does not lay flat in the center of the wheel and the template is hitting the back side of the spoke.
Steeda carries the largest selection of performance and appearance parts for your Ford Fusion. - Cold Air Kits - Swaybars - Custom SCT Performance Tunes - Exhaust Systems - Body Kits - And Much More!
kevjur
  • FFC Senior Member
  • F1 Driver
  • Site Posts: 2796
  • Transaction Count: (1)
  • Date Registered: April 28, 2007, 12:50:13 PM
  • FFC Badge #007
  • Car Make: Ford
  • Car Model: V6,SEL,AWD
  • Car Year: 2007
Re: HOW TO: Check for wheel clearence for the Brembo brake kit
« Reply #1 on: January 06, 2009, 10:23:57 PM »
Thank you sir.
« Last Edit: January 06, 2009, 10:35:14 PM by kevjur »
FusionLife
  • Stock Sucks!
  • Site Posts: 1706
  • Transaction Count: (8)
  • Date Registered: October 08, 2008, 05:22:17 AM
    • Car Domain
  • Car Make: Ford
  • Car Model: Fusion SE I4 with SAP
  • Car Year: 2008
« Reply #2 on: February 10, 2009, 02:10:59 AM »
If the Brembo kit didn't cost three times as much as the most expensive mod I've done to my car, I'd consider it
Check out my Ride
Looking for a great gift idea?
chubbzfusion
  • ChubbzFusion
  • Grand Am Series
  • Site Posts: 444
  • Date Registered: July 02, 2007, 02:01:55 AM
  • Car Make: Ford
  • Car Model: SE V6
  • Car Year: 2009
« Reply #3 on: February 20, 2009, 09:12:59 PM »
oh man ...i wish there was a way of knowing if the brembo brake will fit the rims i want ,
if you dont have the rims available to you cause you have to order them ...=( wut do i do =0
FusionLife
  • Stock Sucks!
  • Site Posts: 1706
    • Car Domain
  • Car Make: Ford
  • Car Year: 2008
« Reply #4 on: February 21, 2009, 12:58:35 AM »
You could try to convince the place you're buying from to check it for you. Other than that I think you're SOL
Check out my Ride
chubbzfusion
  • ChubbzFusion
  • Grand Am Series
  • Site Posts: 444
  • Car Make: Ford
  • Car Model: SE V6
  • Car Year: 2009
« Reply #5 on: February 21, 2009, 04:22:32 PM »
Hopefully they will fit these ,, wut you guys think ???
FusionLife
  • Stock Sucks!
  • Site Posts: 1706
    • Car Domain
  • Car Make: Ford
  • Car Year: 2008
« Reply #6 on: February 21, 2009, 04:23:40 PM »
there's no way to tell from that angle
Check out my Ride
